Points 11 Worker thread Dec 14
  • Points 11 Worker thread Dec 14
    This is the worker thread for Points 11 Solo event that will be held on Saturday, Dec 14 at Oak Mountain Amphitheater.
    As always, we need people to show up early and help us clean up and set up.
    Event is at Oak Mountain Amphitheater.
    Gates open at 7:30, on-site registration/check-in lasts until 9:00, and first car off at 9:30.
    If you have any questions, please contact Mark Kilgore, or myself, John Kilgore and we will try to answer.
    Devotion / 9:15a / Jeremiah
    Early Set Up / 6:30a
    #1 Event Chair / Mark and John Kilgore
    #2 Course Designer / Jerry Ledford/ Clay McCool
    #3 Set Up / Kudulis/ Delanie Calhoun
    Timing and scoring (4 workers) /
    Registration 7:30a/
    Pre-Registrar/Check-in/
    Onsite-Registrar/ Josh B
    Cashier / Mike Wenning
    Waiver station / 7:00a to 8:30 am (worker assignment for the day)
    #1 Tanner
    Waiver Station / 8:15am to drivers meeting (worker assignment for the day)
    #2
    Tech Inspection / 7:30a (worker assignment for the day)
    #1 Heath
    #2 Nicky v
    shadow:
    Safety Steward / 7:30a We need 2 minimum (make sure you get your shadows in)
    #1 Rod H
    #2 Mike C
    shadowing :
    shadowing :
    Novice Directors / 8:30a
    #1 C
    #2 sara
    Blower:
    I don't think Sam will be able to work safety at this event. I need to get one in so put me down in his spot.
      Tech inspection.
        I can do registration. I can be there early for setup too.
        Josh Bassett
        Black 1994 Miata
        CSP 49
          Jerry Ledford, Do you want to design the course?
          If not put me down for course design. I have another "Ultimiate" course in mind.
            We'll be there.
              I'll be there for early set-up.
              Jonathan Kudulis
                Put me down for cashier.
                Gramps
                  I will not be able to make this one. You guys have fun! Jerry I'll see you in STU next season!
                  Sam Copeland
                  Nissan 350Z BSP 2
                  www.RedvsBlackRacing.com
                    Yeah, I have a design. I'll be glad to use it but will need some help from the experienced guys in making sure it's driveable and safe.
                    What time do course designers show up? I might just get a hotel room Friday night.
                    Sam - you better put a cat back on the car to come play in STU Otherwise I'll bump to BSP (not Tire) and we can play there next year.
                      It's going back on, and 285 tires are also going on!
                      Sam Copeland
                      Nissan 350Z BSP 2
                        Can I help keep someone's tires warm?
                        Josh Bassett
                        Black 1994 Miata
                        CSP 49
                          Early setup.
                            I get out there at about 6:15-6:30am depending on how fast McDonalds is with the coffee.
                              Ok, I'll be there. I've got two iterations of the same design in case the first design is too compact with not enough room between features.
