The autocross with PBOC will be on the 16th and 17th of November.
We need volunteers to help with cone shagging. If you would like to work or learn how to setup the timing equipment, then this is a good time to be around.
The schedule is a little difficult, because we are at the mercy of the Instructors from PBOC. Basically if you are going to work the event, you will need to be at the second tier of the paddock by 7:45am and work until around 5:00 or 5:30pm.
We will need a few Instructors to help out with the Novices from PBOC, basically if you have helped C and Sara with the Novices at our events, then you could Instruct a novice at this event.
We will be providing lunch for cone shaggers and Instructors, as well you can run the autocross course as much as you want. We will also be paying $25 a day.
I will be taking a list of names, so if you want to work the event, you must be on this list.
Cone Workers/ up to 5/ Sat only/Sun only/ Sat and Sun are all options
1 Josh Bassett
2 Nick Vagner
3 Justin W
4 Heath Patterson Sat only
5 Chris D
Instructors/ up to 4/ The Novice Car Control Clinic will run from 9:15 to 10:15
1 Nick Vagner
2 Heath Patterson
3 Sean Yoder
4 Sara T
1 Josh Bassett
2 Nick Vagner
3 Justin W
5 Chris D
1 Nick Vagner
2 Heath Patterson
3 Sean Yoder
4 Sara T
