March 30'13 Points 2 Solo event
  • March 30'13 Points 2 Solo event
    I can not say enough about our first event. It was great. I hope we can keep the momentum going. Our second Points event of the 2013 season is open for registration and we ofcourse need workers. Please sign up below, and if you are a new person that is looking to get involved, please let Mark or I know, and we can get you assigned with a group of workers.
    Gates open at 7:30, on-site registration/check-in lasts until 9:00, and first car off at 9:30.
    If you have any questions, please contact Mark Kilgore, or myself, John Kilgore and we will try to answer.
    Devotion / 9:15a Jeremiah Hodgins
    Early Set Up / 6:30a
    #1 Event Chair / John Kilgore/Mark Kilgore
    #2 Course Designer / Cholewa
    #3 Set Up / YellowSS (because Justin or Joseph or Jose hasn't put his name in his SIG yet)
    Timing and scoring (4 workers) / Rod Hardiman
    Registration 7:30a
    Pre-Registrar/Check-in/ Nicky V
    Onsite-Registrar/ Josh B
    Cashier /
    Waiver station / 7:00a to 8:30 am (worker assignment for the day)
    #1 Gramps Wenning
    Waiver Station / 8:15am to drivers meeting (worker assignment for the day)
    #2 Ben Hardiman
    Tech Inspection / 7:30a (worker assignment for the day)
    #1 Heater
    #2 Zac Hardiman
    shadow:
    Safety Steward / 7:30a We need 2 minimum (make sure you get your shadows in)
    #1 Sam Copeland
    #2
    #3 Rod (maybe, if needed)
    shadowing : Jim Farris
    shadowing :
    Novice Directors / 8:30a
    #1 Sara T
    #2 C$
    Blower: Bobby Lyle
    Ben: 2nd shift waivers
    Zac: Heater sidekick in tech
    Me: T&S unless we need a SSS
      Safety
      Sam Copeland
      Nissan 350Z BSP 2
      www.RedvsBlackRacing.com
        I will be there to help set up first thing
        Justin W.
          Ben loves me. Our heights average out to a normal sized man. ??
          Heath Patterson
            I'll do chalk if we can scrounge up some more drywall por favore
            Also, do y'all think we'll have a Wall Station again, or was it more of a one-off thing?
            Charley D'Ambrose
            Boy I remember the first time I got shot out of a cannon!
            '04 Pure White Mazda Miata - STR 77
              1. there's a ton of it in the truck, just needs to be broken down.
              2. We almost always try to put at least one person by it, but if there's not much going on at the civic center it's not always as important.
                Speaking of The Wall, please remember that we need 75 feet between the wall and the defined outside of the course.
                  Devotions! I'll actually be there!
                    Just picked up the blower yesterday from the shop. They tweaked it and they did a couple of pulls/blows on the dyno. I'm not going to say what it's making, but it's pretty strong.
                      It's like turbo.
                        Put me down for pre-reg check in.
                          Timing and possibly registration.
                          Josh Bassett
                          Black 1994 Miata
                          CSP 49
                            No "possible" for registration Josh. That position is too important. Its one thing for set up or for a back up to a position that someone is guaranteed to be there. We need people to be sure that if you are interested in a Registration/Check-in or Cashier position that you make sure you are there.
                            Josh, if you are sure that you will take the position then you know you have it. You've done it plenty of times in the past.
                            John
                              John
                              Just meant I could do one or both, whatever is needed. But I overlooked the fact that Nick has online check-in. I'm not good enough with classing to run on-site registration efficiently so I will just stick with timing.
                              Josh Bassett
                              Black 1994 Miata
                              CSP 49
