Originally posted by rlcsolo2
View Post
Points 10 Charity Worker thread
Fixed it for you Lyle. My bad, I thought I had put you on there permanently as well. I got ya covered now. You are the "boss man" now, so you have a shadow to show the way.Originally posted by rlcsolo2 View PostWell, I thought this was my permanent gig? Oh well. Good luck.
I'd say wearing a mask is definitely the way to go and plan on bringing enough gas to blow the course (mostly the bottom half) 2 or 3 times as they adjust the layout several times before it's finally approved.
Also be prepared for Mike Cavanaugh to find any spot that you might have missed and remind you of it for the rest of the day. Very rewarding.John Kilgore...if winning was easy, losers would do it.
Sorry Lyle, I guess I can over do things in fun.Originally posted by rlcsolo2 View PostAlso be prepared for Mike Cavanaugh to find any spot that you might have missed and remind you of it for the rest of the day. Very rewarding.Mike C.
CS
2019 White MX-5
TVR SCCA Region
"No plan survives reality"
I can't get the Solo rulebook to download, right now, but I'm quite sure it says that you must have a current valid driver's license (or learner's permit, with instructor aboard) to run.Originally posted by G_Racer View Postautocross driving is only for the autocross courseChuck Schultz
He has a license.Originally posted by chuck schultz View PostI can't get the Solo rulebook to download, right now, but I'm quite sure it says that you must have a current valid driver's license (or learner's permit, with instructor aboard) to run.
J-Dog ... I had the same thing a while back. It irked me so bad to be told I couldn't drive.
Just kidding around. You're usually right actually. There have been times that I totally missed cleaning what I thought was "the line" through a feature only to realize that it looks a lot different at speed. It is a exaggerated example of the importance of looking ahead when driving on course. Focusing solely on your line in current corner will have detrimental affects on your line for the corner(s) to follow.Originally posted by mpcavana View PostSorry Lyle, I guess I can over do things in fun.
Also, there have been times they've adjusted the course after I was finished blowing the course (and once after I had run out of gas).
Yes, but we will be co-driving the Gitty to kill the tires. The Evo still has an intermittent misfire issue that needs to be fixed before I beat on it too much.Originally posted by HPEVOX View PostYou coming out Matt?Matt W.
Thanks for the support guys, other than this whole "no driving" thing im fine. I wont b there for this event, but hopefully this next week ill figure something out as far as a diagnosis.Jeremiah Hodgins
99 BMW M3
Understeer is when you hit the wall with the front of the car and oversteer is when you hit the wall with the rear of the car.
Horsepower is how fast you hit the wall and torque is how far you take the wall with you.
