Need some tire help, Nitto NT01
  • Need some tire help, Nitto NT01
    We need a little help with some tires, hoosier's just arent enough to run 2 drivers on the crossfire. Im trying to decide if the Nitto Nt01 would fit, I know a few guys run these on the G35's and was hoping you could help me out, only thing I need is a measurment of the tread width and overall height, just to see if it would clear the car.
    Thank you
    Carvel Webb
    HS 155 Fiesta, retired crossfire/370z
    I'm running the NT01's on my G35, with 225/40/18's on the front, and 245/40/18's on the rear. I measured the rear's at 25.5" tall and about 9.5" wide, which is pretty close to the spec per http://www.nittotire.com/Tire/nt01#size.
    Let me know if you have any other questions...I'll be glad to help!
    Andrew Reynolds
    TVR Youth Steward
    1994 Mazda Miata Turbo Black SSM #0 (Autox)
    1999 Mazda Miata SC Greenish MR #0 (RallyX)
      Thats what I needed, thank you for the quick response
      Carvel Webb
        you should run 245 in the front. Makes a big difference.
        Sam Copeland
        Nissan 350Z BSP 2
        www.RedvsBlackRacing.com
          I have actually been considering that, but a little worried about the rollover onto the sidewalls being worse with 245's on an 8" rim (front). On the Nitto's I'm already running 50 PSI cold to keep them from rolling over. I bought a used set of the R-S3's that I'm going to run after the Nitto's are trashed, and they are all 245's, so I guess I'll find out pretty soon. Thoughts?
          Andrew Reynolds
          TVR Youth Steward
            it should be fine. I am going to run 255s on a 8.5 in wheel next year.
            Sam Copeland
            Nissan 350Z BSP 2
              50 psi to keep them from rolling over? Is your front suspension 20 years old or something?
                No, it's a G35 with no camber adjustment, and the sidewalls on the Nitto's are kinda soft, and there's a lot of weight in the front end, etc. I was running the Dunlop Star Specs at 40 in the front, so was pretty surprised that I had to keep going up on the NT01's to keep them from rolling over. It took me 3 events of chalking the sidewalls to convince myself that that was the right pressure...now after 6 events (dual drivers) the tires are almost shot and I'm thinking about trying the Hankook R-S3's next!! The joys of autocross!
                Andrew Reynolds
                TVR Youth Steward
                  If I get 6 full events with Carville and I driving I would consider that a win
                  Carvel Webb
                    Last event I ran 30 in the front and 28 in the rear. The rs-3s never rolled over.
                    Sam Copeland
                    Nissan 350Z BSP 2
                      Have you ever taken tire temps during an autox?
                        Yes, I have done it fairly consistently since getting the NT01's (still trying to convince myself that the pressures are right!). I'm typically seeing temps in the 140-160 deg range and within 10 deg F across the tires, usually with the highest temps on the outside of the fronts and the inside of the rears.
                        I really love the tires and they feel great and are very consistent and predictable...but unfortunately I cannot afford to replace tires 3X/year.
                        Andrew Reynolds
                        TVR Youth Steward
                          The RS3's are a great tire. I dont think you will see much of a disadvantage going with that from the NT01.
                          FYI, biggest tire you can squeeze on the rim is usually the winner for AX. first year of the "new" AS class we took my friends Ed and Mickeys Boxster to nationals. went with 255/285 on 8" and 9" rims. I got 3rd. the car that took 1 & 2 squeezed 285's on all four corners of thier cayman. and you could visibly see the difference on course with the cars running. ours was pushing in places where thiers wasnt. lesson learned.
                          You can't unpull a Trigger
                            Note that Trigger says "usually". I believe his comment mainly applies to r-comps. Street tires have to be more carefully matched to rim width. The 225/45-15 RS3 is a good case in point. It is good on a 7.5" wheel, better on an 8", and best on a 9".
                              Rod, that is pretty standard practice on any tire. A wide tire on a narrow rim will have more overall grip than a narrower tire, but will not have the transitional response of the same wide tire on a wide wheel. So, turn in is better on the 9" wheel but mid corner grip is about the same between the 7.5" and the 9".
                              At least, in theory ...
