ST or HS for 2012
  • ST or HS for 2012
    I am really unsure on how I want to proceed and looking for inputs. As I see it:
    Pros for ST:
    already feel like the car is maxed out in current form
    more tire
    cheaper tires
    lots of competition
    Cons for ST:
    cost of modifications
    car is kinda out classed in ST even fully prepped
    Pros for HS:
    R comps
    less mods/ more streetable
    fairly competitive in HS
    Cons for HS:
    lack of competition locally
    tiny wheels = smaller tires
    I keep running over this in my head, and while there are more pros for ST I can't say they outweigh HS. So please guys help a brother out.
    Can't help much, but keep in mind "ST" will not exist after this year. It is being split into STC and STF, with most, if not all, of our local ST folks going into STF. The Mazda2 will be STF.
    Depends on where you want to run I guess. If locally then I think STF is a no-brainer due to tires/wheels, competition, and freedom to make some changes to the car.
    Then again, Don(?) in the Hyundai Accent has been a consistent entrant this year. Y'all could have a little two car battle for 2012 in HS.
      Nobody runs in HS. Just pick an up class and run in it.
        SM! hehehehe
          HS. R comps are crack.
          - Jordan, GS-15
            Make the STF mods. If you succumb to rcomp crack you can always beat up on the XP crowd
              Yeah, A6s and some Koni adjustables might go a long way.
                This is just what I need...a freaking green turd to take a dump on my chances at anything...
                  I've got an LT-1 you can put in your .......hold on wait. nevermind.
                  although there may be another car you can drive. or should i call it a seat on a motor you can drive?
                    Mm indeed...
                      the lt1 weighs more than my car
                        most everything weighs more then your car.
                          I weigh more than your car.
                            and that is before he eats the 16 pack nugget.
                              Woa, where can you get the 16 pack? I feel ripped off that I've only been getting 10
