Points 9 worker thread
  • Points 9 worker thread
    2011 Points Event no. 9 will be held at Verizon Wireless Music Center, Sunday, October 16. Please post up here for positions on the setup crew.
    For those of you who want to be on the setup crew but have never done it, show up early and get a feel for what is needed. Help out where you can and learn from those who are there. These are your events, if you want them to be great, help to make them great.
    Devotion / 9:15a
    Early Set Up / 6:30a
    #1 Event Chair / John Kilgore/Mark Kilgore
    #2 Course Designer / Nick Vagner
    #3 Set Up / Griffin Burkett (i believe Eileen and Megan are coming)
    Timing and scoring (4 workers) / Jon Glidewell/Ervin/Nick V
    Registration 7:30a
    Pre-Registrar / Jon Glidewell
    Onsite-Registrar/ Matt Williams
    Cashier / Katie Williams
    Waiver station / 7:00a to drivers meeting is work assignment for the day.
    #1 Ben Hardiman
    Tech Inspection / 7:30a
    #1 Zac Hardiman
    #2 Ervin
    Safety Steward / 7:30a We need 2 minimum
    #1 Rod Hardiman
    #2
    #3
    shadowing :
    shadowing :
    Novice Directors / 8:00a
    #1 Sara Tongsuvone
    #2 Chaisit Tongsuvone
    Guy with backpack blower to get rid of the top layer of gravel prior to the first run group / assist with novice drivers
    #1 Lyle
    Design and course set-up
    Griffin Burkett
    Silver 07 Civic with yellow wheels brighter than the sun.
    SMF 15
      Just confirming.
        will not be there
          The Hardimans will be there. I can be a SSS, but we really need someone else who has finished their paperwork to step up and get some events under their belt. They are going to need it when it comes time to renew their SSS license.
          Ben: early waivers
          Zac: help with tech
            Katie and I plan to be there. We can work registration.
            Also, I have one of the timing lights with me for repairs. It's fixed and I will bring it on Sunday.
            For the equipment setup people, we really need to be careful with this equipment. The mount was cross threaded in to the timing light last event, which broke one of the mounts and damaged the threads on the light.
            When setting up this equipment, please be careful to not cross thread the mounts or over tighten anything. We have purchased some tripods to mount the lights on, which will be more stable than the old mounts, but the "locks" on these tripods are plastic and fragile. they will break if overtightened.
            I tested these on Saturday and they require very little tension to hold firm and are much easier to aim than the old mounts.
              I plan to be there and can help with t&s like last time.
              Jon G.
              '90 Mariner Blue Miata
              '08 Met Gray Mazdaspeed 3
                We will be there as always. C & Sara
                  Jon,
                  if you'd like to also show up earlier you can help out with Registration as well. I know that Micheal Cholewa will not be there for this event and I'm sure Matt and Katie would not mind the help.
                  Just a suggestion, not mandatory.
                    John or Eric doing devotions? :-)
                      I think you're the man Jeremiah
                        I'll help with tech... and setup if needed
                          agreed
                            Don't know if I'll be able to make this one. Looks like the RX7 won't be ready yet and I may have to work. I will keep everyone posted.
                            -V
                            Vincent C.
                              Jon,
                              They showed me how to do all that last time too. I plan to be there around 7-7:30 to help where needed for registration.
                              Jon G.
