Tire dilemma...
  • Tire dilemma...
    Not a bad dilemma, but a dilemma none the less. We have two almost new V710's and I was going to rotate them to the back and get two new 710's for the front. Now, I'm thinking about blowing that off and just grabbing 4 A6's for the Atlanta tour.
    Is it worth double the money to grab the A6's? It's been a long time since I had new Hoosiers and I honestly can't remember if they are really that much better than the 710's.
    Feedback is greatly appreciated.
    www.gm-technologies.com
    The A-6's are much more sticky and lighter than the 710, but the 710 will outlast the Hoosy's at least 4x. I still have some 710's that have been through 3 Talladega TT's that have usuable tread. If you want to lay down your best time, go Hoosiers.
      Can you get enough negative camber to make the Hoosiers really work for you on the Mini?
        The new pair of V701s for the front with the older ones on rear should do fine and help rotation a bit. The V710s do last longer but tend to start loosing grip before the tread is gone. Kumho has contengency again, so I would go that route...
