Question on vehicle identification
  • Question on vehicle identification
    I don't see anything in the rule book about using strokes for letters. Would it be legal to use a heavy stroke only? Essentially, a body color number/class with a heavy outline for contrast?
    It's p. 40 of the rule book ...
    As long as it is easily readable (which is what the rules try to accomplish), it should be no problem. But I would go with a solid contrasting number that is (at least) the minimum height. After all, it is harder to read when you are speeding by at 60mph! I have seen people talked to at National events about "cool" numbers that were not easy to see...
      What I've comped is very easy to see, and huge. I know that big numbers aren't automatically easy to read, but I think these are good. No odd fonts or anything. If there is an issue, I'll just take them off and run my magnets.
        you should be fine, I'd imagine
        Andrew Maffessanti
        Atlanta Region SCCA
        114 DP
        www.DIYAutoTune.com
