Just saying that the A6 is a much better chassis than the older Volvo.
Time to call in reinforcements!
Ok guys so here is the latest. Purchased 2 turbo kits recently and only lack a few things being complete. A set of injectors, hondata (or megaquirt) and a Tial wastegate. My question is injector sizing. I can get a set of DSM 440cc injectors for around $150. My question is this large enough for my application. I have seen a similar build on a D16Z6 with 250whp and 200lbtq running 390cc DSM injectors. I assume these power numbers will be close to what my B16A2 will put down. However, I used RC's injector sizing guide and they recommended 460cc injectors minimum with fuel pressure being 50PSI at the rail @ 80% duty cycle. This just doesn't seem right to me.Last edited by Shaggy; 03-03-2011, 12:34 AM.#20 SMF Civic - Lacy Ingle
http://www.CivicPerformanceParts.com
Not sure if they are the right style or not (low impedance), but OE Evo injectors are 550cc and just as cheap as DSMs. There is also the option of the older WRX injectors which are high impedance (I think ... opposite of the Evo) and can be modified for around 800cc I think.Matt W.
You can pick up ford injectors that are lowZ that flow 46lb/hr for pretty cheap. Look on turbobricks for people selling injectors, probably pick up a set for under $75.
The "Browntops" will also work.
Your biggest issue is going to be tuning. Get that sorted.M. Cholewa
What year Civic is the car or better yet what year is the wiring harness?
Originally posted by TouringBubble View PostNot sure if they are the right style or not (low impedance), but OE Evo injectors are 550cc and just as cheap as DSMs. There is also the option of the older WRX injectors which are high impedance (I think ... opposite of the Evo) and can be modified for around 800cc I think.
Originally posted by Cholewa View PostYou can pick up ford injectors that are lowZ that flow 46lb/hr for pretty cheap. Look on turbobricks for people selling injectors, probably pick up a set for under $75.
Originally posted by engled View PostWhat year Civic is the car or better yet what year is the wiring harness?Last edited by Shaggy; 03-03-2011, 09:47 PM.#20 SMF Civic - Lacy Ingle
this may confuse you even more, or it may help you out tremendously. it sure helped me when I was looking for injector flow rates and what I could use.
Originally posted by Shaggy View PostWould I need to use a different rate if I choose to tune on E85 instead of 93? I know that the Air/Fuel mixtures are different between the two. I'm trying to stay as cheap as possible I'm just not sure how to calculate the proper flow rate for my application.Matt W.
Originally posted by Shaggy View PostThe car is a 93. The engine is from a 2000 Civic SI B16A2 with a p28 chipped ECU.
Originally posted by c-evoVIII View PostI have a set of stock Evo injectors for cheap if u looking. C
Originally posted by TouringBubble View PostYes. To run E85 you need approximately 30% more fuel and the pump/regulator to back it. A 255 lph pump and a 1:1 rising rate regulator are a must along with bigger injectors, but those should be standard for a turbo application. They will work for either and you'd just need more injector.
Hoping to have all this stuff rounded up in a few months after my suspension is done. So far 340lb F&R springs on Tokico HPs with no sway bars & falkens just ain't cutting it lol.#20 SMF Civic - Lacy Ingle
