North vs South Results
  • #61
    Originally posted by rodhx View Post
    Not ST, engine is too big. STX maybe?
    3.5L in the 635csi...has cats.....8" and 9" tires...aka not 7.5 ....unless I swap to some ancient wheels I have (stock) but I'll still have springs and no exhaust after the cat....so still str (i guess?).
    Originally posted by TouringBubble View Post
    ST as long as displacement fits, you have a cat and tires are within 7.5". Some other small things too ...
    maybe I'l run 215 r888's on the 6, or the 240 on shitty streets....I guess the 525 is defintely F-stock...but holy hell it is slow...I don't know if I could live with myself running it. I'll probably run the 6 in STR if I get my brakes in time, or the 240 in SM....I'd have to be paid to run the 5 in F-stock.
    e34 540i/6
    e30 318is/5
    e30 344is/6
    • #62
      Just a thought for those of you registered on axware for the Huntsville event. Last year we used the "tire brand" info in the registration to designate club allegiance. Do this by editing your registration (not your garage) and putting ALSCCA in for tire brand. No biggie if you don't, but I think it helps for proper accounting, especially since we have so many of our new folks heading northward. Read that as "it keeps them nefarious TVR folks from claiming you for themselves", 'cause if you don't claim ALSCCA come registration time Sunday morning you will be counted toward their score.
      I did not see a way to do this when initially registering, so I think you have to register and then edit that registration to get to "tire brand"
      Also, my boys & I will be heading up I65. Anyone care to meet us at either exit 282 or some point further north?
      Charlie
      Black BMW Z4
      • #63
        Rod, I tried to edit my registration to enter ALSCCA but I couldn't find the icon for Tire Brand in the edit menu. Help! How do I accomplish this task? Charlie
        Charlie
        Black BMW Z4
        • #64
          The 6 is most definitely NOT a STR car. It ought to fit in STX which allows normally aspirated engines up to 5.1 liters, wheels up to 9", and tires up to 265mm. Of course for any ST_ class tires must have treadwear rating of at least 140
          • #65
            Charlie, check Matt's post on page two of this thread...about #42. And no big deal if you can't edit the online registration. Just be sure to tell them when you register on site.
            BTW, which way are your heading to Huntsville?
            • #66
              copied and pasted from the handbook (off the scca website)
              A. Tires may have section widths up to and including the following:
              ST, STS, STR (AWD) – 225 mm
              STX (AWD), STU (AWD) – 245 mm
              STR (2WD) – 255 mm
              STX (2WD) – 265 mm
              STU (2WD) – 285 mm
              my rears are 255's
              Any wheels are allowed with widths up to the following:
              ST, STS, STR (AWD) – 7.5”
              STX (AWD) – 8.0”
              STX (2WD), STR (2WD) – 9.0”
              STU – unlimited
              My street tires are treadwear of 200, unfortunatrely my r888's are 100...dang I wish I had Rcomps on the SM 240...stupid stretched 225's vs. rcomp 255's I could easilly fit. I won't lie though...logic/competitiveness have little to due with which car I will run. Priority will be; Car that is running>Car that will pass tech/won't light on fire>Car that is funnest to drive>Competitive...lol?
              e34 540i/6
              e30 318is/5
              e30 344is/6
              • #67
                You gotta check which cars are eligible for the various classes, listed on page 171 or so of the rule book. Only certain cars, most of the roadsters, are eligible for STR. The 6 ain't one .
                The 6 would be in STX. r888's are illegal in all ST classes.
                • #68
                  I am a man. I do not read books- I burn them.
                  I'll just claim D-stock, and punch anyone in the face that disagrees...than clarify that any disagreement with my punching will somehow involve se***al fluid.
                  Pretty sure I am covered on every front.
                  e34 540i/6
                  e30 318is/5
                  e30 344is/6
                  • #69
                    sounds like a plan
                    • #70
                      This does not read as funny as you might have thought.
                      Mike C.
                      CS
                      2019 White MX-5
                      TVR SCCA Region
                      "No plan survives reality"
                      • #71
                        I rather enjoyed it.
                        • #72
                          Disclaimer:
                          Nothing I say should be taken very seriously, unless I explicitly state that I am being serious, and in that case it definitely should be ignored.
                          e34 540i/6
                          e30 318is/5
                          e30 344is/6
                          • #73
                            Sounds like a talker, not a driver. Not many points available for talk
                            • #74
                              I lost a brake pad @ tgpr - but they are supposed to be here tomorrow. As long as they come in I can rock the 6.
                              What is D-stock + missing exhaust, springs, and wider tires?
                              It looks like the 635 in that trim is ESP.
                              • #75
                                There is more truth in that then you know...except sadly I probably can talk my way past the 1 point I made driving...At least I can get at least a 100% increase in my points just for showing up
                                e34 540i/6
                                e30 318is/5
                                e30 344is/6
