i was going to go and get some made and was wondering is there anyone on here i can check to see what number is ok to get. i was wanting to get them made before the next event. i guess im going to be running in the st class.
class numbers?
You can check "reserved cars" on axware (where we do online registrations) to see what has been used in each class. For ST it looks like the following are taken: 1,8,11,15,17,27,30,82
Maybe the T&S will confirm, but I believe this listing only contains cars for those who do the online registration. Seems like that is about 50% of turnout each month, so there may be "regulars" whose numbers are not in that list. You may want to wait and see who shows up on the 23rd before ordering.Rod H
Yeah, just get 2 different numbers and you can switch them around if needed.Matt W.
Originally posted by TouringBubble View PostYeah, just get 2 different numbers and you can switch them around if needed.Bill Clinton "It depends on what the meaning of the word 'is' is."
Good call.
Also, if you get numbers from somewhere like iZoom, you get 2 numbers and 3 letters in the standard package. Since you run ST, you can get an extra letter, like an M possibly, to cover future class changes if you expect them.Matt W.
Don't get 8 or 88 'cause it reads the same with the shiny side down and the greasy side up!
Don't get numbers in the hundreds because it will read like a two digit number with a 1 in front indicating a second driver. Timing and scoring will go nuts. I've seen that before- it's not a pretty sight!David Branch, Sr. / STS 21 Black Beauty / XP 21 Agent Orange / Helmet designs by AlanB
Can we all just agree to ignore whatever comes after Blue Ray? I don't want to have to restart my collection ...... again.
im going to order mst 34. i can use st 34 or 43 and like touringbubble said with my 3rd letter im going to get the M. that way when if i decide to turbo or do the ls1 swap way down the road i can use it for SM class. i know im going to had bigger brakes,coilovers and better tires down the road also.
