tire question for the rallycross peeps
  • tire question for the rallycross peeps
    Changing my tires after this weekend, noticed some wear on the front tires. When i first mounted them i marked the position and be putting them in the same spot. As of now i have 4 events on them, when should i rotate the tire positions? Pic shows the left side rear and front.
    If you want balanced wear, I would. The front is definitely seeing more wear.
      I rotate mine every time I put them back on.
        Damon on the Escort(FWD) I never rotate the tires. When i went to the NC I rotated so I basically had a new set on the front, when I got home I rotated them back. I will repeat that this year. My rear tires have shown more or less zero wear..... And I am too cheap to buy new fronts just for thr NC! The wear is dramatic looking at first (Winterforce) but soon slows down.
        Ford Escort #717 rallycross
        Bmw e21 #17 track car
          I would rotate those if that's from one event. What tires are those?
          I haven't seen that much wear on my tires since I started rallyx... maybe I should drive harder? I probably have 15-20 events on them. But mine don't look as aggressive, more like all seasons. They are Yoko Guardex 600s that I couldn't even give away before rallyx.
          Maybe I need new tires if I want to stay on top in SA?
          Wes
          86 Audi 4000q
            Wes, you didn't see Damon blasting that Festiva around? sheesh kinda looked like God just grabbed it and was going "vrooom vroooooooommmm vroom" with it around the course.
              Lol, yeah i do have a kinda "go for broke" driving style. Dillon pointed thatout to me this past weekend.
              Wes, those tires are called Sunny SN3680. I got them from tires-easy.com and were the only winter tire in a 165/70-13. The size was the only reason i got them, it was just a bonus the tread patten lookes like a hankook.
              Thanks for the input guys, im gunna start swaping them every event to even out the wear. They not really worn per say, just chewed up a bit at the edges.
